I Purchased these parts for my PC Build, but I wanted to know if the 430w Corsair power supply would be enough to power the machine. I ask because after browsing the builds here, many use a 500-600w supply. if the one I choose is not sufficient could anyone suggest something? Thanks for the help.
This is the build: http://pcpartpicker.com/user/pdgonzalez/saved/3yaA
*Btw this is not the price i paid although i did get everything from amazon.
in all seriousness a 500 watt is really minimum you will want, never cheap out on your psu wattage and if you ever want to upgrade you most likely won't need a new psu. therefor making a new system nicer on your wallet
