Is this ok for first build?
well i know my stuff with pc's but im on a budget and im not good with budgets -.-
so which is better:
http://pcpartpicker.com/p/BdS2
or
http://pcpartpicker.com/p/BdSU
yeah i know they are close enough the same but really its a test of price to performance ratio.
oh and its for gaming
and i can spend either $650 or $750 but i can only spend the extra $100 if its worth it
or should i save slightly more and get a fx 4100
oh ill be playing skyrim, crysis, planetside 2, dota 2, trine, metro 2033 and other games ...........               i know ive picked loads of pc intensive games lol.
any suggestions are welcome
get the FX-4300 or Phenom II 965 over any of the bulldozer chips
why are these better?
and the fx 8350 ect. are piledrivers are you including those cpu's under bulldozer because some people do?
http://pcpartpicker.com/p/Bf8t
thats the model for it basically with no cpu
so the competetors are:
amd fx 8350
amd phenom II 965
amd fx 4300
(i would get a intel but in my last build i had many issues) so i guess this isnt my first build but my first "modern" build my last one was a couple years ago
