Hey guys, I'm building a new pc and have ordered the parts, but the heat sink came in and I'm not sure if it's going to fit in my case. On the website it said that it was 120mm long, but on the package it says 158mm long, and I can't find a number on the clearance for my case. Thanks.
a Noctua NH-D14 also fits in the Thor. so the Cooler master Hyper 212 evo would definitely not be a problem. There is about 170MM clearance for the cooler, till it touches the side panel. so cpu heatsinks upto 168mm fit without any problems at all.
Every time I have doubts whether certain parts will fit, I just look at PCPartpicker completed builds and filter out the exact parts i'm looking for. In your case I found this : http://pcpartpicker.com/b/I1b
