Am I going to have enough room for the heat sink etc.
what do I need to clean/put on the heat sink
how do I make the optical drive look good
case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139026
parts
http://pcpartpicker.com/p/2BtQz
thanks
looks like it should work
for making the optical drive look good, you could (depending on how easy the cover plate is to remove off the case) recess the optical drive and remove the cover plate every time you need to use it. or you could do some modding and make a door kinda thing.
