Don’t want it to short out
I’m kinda confused, are you asking if the bracket will work to mount the hard drive to something? If so I don’t really see why it wouldn’t. If you’re still worried you could put some paper trimmed to fit between the bottom of the drive and the bracket for an extra layer of insulation.
Yea I was worried about the open pcb on the metal.
I found an old plastic mount
Just taped it up in there g2g for now I guess
That is going to short the PCB. Don´t do that.
you can pick up some nylon washers to place between the drive and bracket (or you can make them yourself from a plastic milk carton.) just add enough layers to keep the pcb from touching metal.
cant tell without a side view but it appears the drive is in the wrong side of the bracket!
@Seventy_3 is there any way you can show us a picture of the pc case internal ? What is the end goal here – have you run out of room to place disks? Perhaps we can suggest a different place to mount the disk.
OMG GUYS! the god damn disk tray is coated with black paint… Unless the OP scratches it up pretty good he is fine.
To the OP. At most you could just go to a hardware store and get a bunch of M3 nuts to make a standoff. The M3 nuts are useful in PCs anyway. Just grab a few.
