Why not just wait 3 months so you dont have to settle for an apu? You could then get something like this >> http://pcpartpicker.com/user/deejeta/saved/3XZp
+1 why wasting money on an APU, if you planning to get an dedicated GPU? i would wait till you have enough money to build the rig. the athlon 760K is a good choice with a GTX760. only in games that are also abit cpu heavy, the athlon will bottleneck the the GTX760. for example metro last light.
+1. I would save up as the current plan that OP is running on will be more expensive in the long run. Either that or you could get a better computer later.
