Is this a good fan controller?
Oh look, I'm back. Did you miss me?
Anyway, today I was looking for a fan controller for my new fancy build.
I've had a look at a few and I've come to the conclusion that I quite like the NZXT Sentry 2.
Do you think this is a good controller? If I'm stupid and it's a pile of crap, please suggest another! No more than £50 please, and only one slot tall. Also, 3.5/5.25" is OK, and 4/5 fans max :)
Also, can you use the CPU fan on these? I hope you can... (I am aware that the Sentry 2 only has three pin connectors, but if I can get an adapter I'll use that)
Thanks for your support, half of this build is like this thanks to this place! :D
Yes it is
Depending if you have got your case yet, any case inbuilt controller will work amazing. and will look better
Just personal opinion
