Is there a recommendable linux compatible camcorder, or a way to pull data off a sony CX405?
ive got a sony CX405 that ive ben using for a few years now. do yall have any ideas to pull the AV data off it under linux? under windows i have to use playmemories home. last time i tried, i only got that software to launch via WINE, but never got the software to see the camera.
failing that, can yall recommend a camcorder that will work under linux? ive got a 128gb micro sd xc card that id like to still use with it, and im happy with 1080p res.
does the camera volume shows in lsblk?
Maybe try running dmesg -w and connecting the camera, paste the result of the last lines here
i couldnt get the 1sblk command to work, but i did see the camera when i ran dmesg -w
sorry, it is lsblk the first letter is lower case L
ah. yes, im seeing the cameras storage with that command
ok, mount it
mkdir cam; mount [camera device] cam
and use f-spot to download the videos from the device.
ok, i believe its been mounted because i can see the folders in the file manager. but this mint install im using doesnt have f-spot, and i cant seem to find it for download. so i guest ill have to try something else
