Is there a performancediffrence, if you stick a USB2 device into a USB3 port?
I wasn't able to find that on google, I guess nobody thinks about that.
I don't believe there is. Your limited by the slowest factor. Usb 2.0 devices are only capable of their designed speed, plugging it into a 3.0 port will be the same as if it was a normal usb port.
The USB 2.0 device will work at USB 2.0 speed, not USB 3.0 speeds
certainly not 3.0 speeds, but i've deluded myself into feeling that my flashdrive transfers faster in a 3.0 port
ofcourse it will not have USB3 speed, but is there a diffrence?
No, there isn't.
USB3 has more pins which are on the bottom of the port, any USB2 device you connect on a USB3 port will only use the 4 USB2 contacts.
ok guys, thank you very much
