Is the Kingston HyperX Beast going to fit onder a Noctua NH-D14 SE2011?
Here is my order list: http://ca.pcpartpicker.com/p/AJEJ
Why such a bad gpu? Just upgrade to a 100i or nxztx60 kraken and you wont have an issue.
I already own 1 of the GPU to i was gonna crossfire it.. and a also own th noctua, i just want to know if the memorys will fit.
i have the cooler and i needed to use low profile ram so  99% answer is no
You can get 32GB of different 1600 ram for the same realworld performance for under half the cost of that HyperX Beast. $400 is way too steep for some ram in my opinion when a $400 dollar GPU would do you about 10x as much in terms of performance gains. You could sell your 6950 (Still a good card) to someone and spend that to increase your limit on new GPU too so you could grab something even better. Just my 2 cents
Here is what i would go with http://ca.pcpartpicker.com/part/gskill-memory-f317000cl9q232gbzh
Better specs for nearly half the price
Also Sell your 6950 For ~$170 and buy a 7970
And for the heatsink for for a h100i Or something
Thanks for all the ideas guy's. I was searching and i found this :P
http://www.noctua.at/main.php?show=compatibility_ram_gen&products_id=34&lng=en#DDR3_Kingston
