Is the Corsair CX600w psu enough for my system?
HI,
im going to build my first pc and im wondering is the Corsair CX600 W Power Supply able to power my system
SPECS
CPU:intel core i5 3570k (will overclock)
motherboard:Asrock z77 extreme 4
GPU:gtx 670
Ram:8gb
Psu:Corsair 600w
wil the Corsair CX600 W psu be able to power all the pc.
Thanks in advance .
Should be fine as far as I can tell. If you plan on going SLI then you may come short.
Definitely more then enough, but would you please look at other options? A budget CX series is not worth the money now a days with all the other options out there. Have you looked at otehr power supplies like the XFX 550 or even a Seasonic 520?
Here is a link to how much power it pulls, 311watts max load with a OC 3960x+GTX670: http://www.anandtech.com/show/5818/nvidia-geforce-gtx-670-review-feat-evga/17
Would i dare say even a really good quality 450watt unit would be able to push it?
