As I stated in my last post I have been looking for a 780 and I came across the PNY 780 OC that doesn't have a lot of media coverage so I was wondering if PNY is reputable and if this card is any good in performance?
A 780 is a 780, 780s are all the same. Sure, some company might OC one, but you can too. PNY is no different than any other GPU maker.
PNY usually offers a lifetime warranty on there gear.
PNY is a smaller brand than for example MSI or ASUS so they don't ever get a lot of media coverage. There cards aren't usually chosen because if you are going to spend $500 on a graphics card, you might as well just spend an extra $20 to get the ASUS or MSI. Also PNY doesn't really make a custom cooler like ASUS or MSI does so there cards wouldn't run as cool as the ASUS or MSI.
Ok sounds good, I'll just buy the cheapest at the moment.
PNY is a partner company of Nvidia, and also makes all the Nvidia workstation graphics cards so yea they should be a good card to buy. Plus that lifetime warranty just like a workstation card.
http://www.nvidia.com/object/IO_20020822_6482.html
http://www3.pny.com/Categories/ProfessionalGraphics.aspx?Category_ID=17
