Hey guys, I bought a gaming pc recently and here are the specs:
AMD 8350 4.5ghz
asus m5a99fx
noctua nh-d14
gigabyte 7970 oc edition
samsung 830 128gb ssd
WD caviar blue 1tb hdd
nzxt phantom 810 case
antec 850w gold certified psu
The thing is, I've overclocked my 8350 to 4.5 ghz stable with temps reaching 57 degrees in prime 95 (only ran for 40 mins). I've realized that while gaming, I'm no where close to maxing out my cpu load. I was wondering whether or not overclocking my CPU is worth the added stress on my cpu if im only using it for gaming. Games I play are Bioshock infinite, BF3, Crysis 3, CS:GO, Far Cry 3 Blood Dragon, etc.
Keep the overclock, you will probably need it. Especially with a HD 7970.
Crysis 3 needs a fast CPU, especially when there is a lot of AI activity going on.
My poor little i5 2400 was struggling in Crysis 3. As long as your temperatures stay within the safe range (under about 65c I believe) when running Prime 95 then in real world situations it's never going to get as hot.
People do say that overclocking decreases the life span of the CPU, but honestly by the time your CPU would die you will have long gone and sold it because it became so outdated.
If it's a moderate OC without a large voltage bump, then yes. With the FX, I'd wager 4.5GHz is pretty moderate, especially if you're still able to have the power saving features enabled while still being stable. The temps are good.
Well, CPU load indicators aren't the best indicator in my experience, especially if it has Turbo enabled. When playing Fallout 3 on my C-60 netbook, neither CPU core was fully loaded (~60%), and the GPU wasn't fully loaded either, but I still never got 60 FPS, and switching from medium @ 1366x768 to lowest settings and lowering resolution to 800x600 didn't help performance, which is an obvious CPU bottleneck.
Also, that OC will help in games that don't scale well beyond 4 cores, and the titles that do scale well aren't particularly common yet.
Thanks for the feedback guys! I'm going into college and I need that pc to last anywhere between 6-8 years so I might look into lowering the temps to around <55 degrees peak in prime 95. Any recommendations?
High static pressure fans on your heatsink or radiator, and high quality TIM. I'd recommend CoolLaboratory Liquid Ultra if you want the best thermal interface out there (take this with a grain of salt - I mean thermal interface for heatsinks, not in all of Physics).
with overclocking you're maximizing the value of your build, the cpu you choose + the cooling option. so i dont think it's necessary for gaming but it also doesnt hurt (other than cpu longevity)
