Is normal class 10 sd card speed the maximum speed, at which a smartphone can operate an sd card?
So I am going to buy an SD card for a smartphone. Is there a diffrence if I use an SD card with 10 mb/sec vs 45 mb/sec (MicroSDXC Class 10 UHS-1 cards, which are still rated class 10, but are much faster then 10 mb/sec read speed) on a smartphone? I am planning on using 4gb of the SD card as swap usage for the smartphone to.
Thanks,
Giant
you may load emu's and apps slightly faster, if your going to play psp games on it then absolutely yes
Depends on what your using it for. Not sure what swap usage is, could you explain a little more?
Also wrong forum please delete this and repost in hardware-other section.
Its not the wrong forum.....
Its about phones, in the phone section
To be more precise:
1. I want to know if smartphones can access this speed, which will automatically of course speed up my "swapusage" in my android device, with this software: ROEHSOFT RAM Expander
http://www.androidfanclub.net/2013/08/increase-ram-on-android-with-ram-expansion-tool.html
2. If smartphones limit the speed, this question doesn't have to be answered, but would be interesting still: How much of a difference is there in everyday tasks (yeah, opening a game would be probably one of the most intensive, and therefore one of the biggest differences) such as playing a music file, open a picture etc.?
Edit: And what are emu's?
1. Depends on if your phone is running out of ram. You can download a task manager or a ram usage app to see. If you have less than 30 or 40 mbs then you might need more. Android automatically clears stuff if you need more room so don't expect to see like 1mb because it wont go that low.
2. The difference all depends on you ram usage, ram is like a storage container you can fill it up all the way, then you need another storage container. Getting a second storage container will never help if you haven't filled the first one. If you do need more ram your'e gonna want a micro sd with high 4k read and write performance. 4k read and write is small pieces of data going around the sd card, which is what ram will be doing.  The micro sd with the highest is the san disk class 10 UH-1. http://www.amazon.com/SanDisk-MicroSDHC-Memory-Adapter-SDSDQU-032G-AFFP-/dp/B009QZH7BU/ref=sr_1_sc_1?s=electronics&ie=UTF8&qid=1390242608&sr=1-1-spell&keywords=micro+sd+san+disk+uh+1
Funny you asked because I was just doing tons of research last night on which one had the fastest 4k, which I needed for a bootable linux on the micro sd because mine was too slow.
Edit: to answer your original question no, and class 10 is the fastest they make, then class 10 uh-1 is faster, then the fastest ever as of writing are Sandisk Class 10 UHS-1 Extreme.
Also emu is short for emulator, which is something that pretends to be another, a n64 emulator makes your device pretend to be a n64 to play n64 games. I'm guessing your talking about emulating ram, which is referring to your micro sd pretending to be ram, so it can be used as ram.
I would look to see if the phone you are planning on putting said SD card in is even capable of reaching those speeds. There could be a hardware limitation on the SD card reader portion of the phone.
Thanks waitwutmyname, and yes zanginator, it's also important if the smartphones can handle those speeds. Or if different smartphones can handle different speeds. My phone is going to be: Newman K1B (phone from china). So one question is still standing: How much of the sd cards speed can smartphones read? Or are different smartphones able to read different speeds?
