Is my water cooling pump dead?
Came home and booted up my pc and cpu instantly went to 90-something degrees.
I have applied new thermal paste to the cpu but alas it was for naught.
I now suspect that my pump is dead since I took of the lid and there doesnt seem to be any water movement at all when powering on the pc. I also tried unplugging the 4-pin connector so it would only draw power from the molex but still nothing.
Is it dead? Is some whole other part at fault? Am I missing something or am I just fucked?
in bios temps just rise and rise and the fans go fucking loooud.
some specs:
i7 4790K
asus vii ranger
Custom loop: EK DDC 3.2 PWN, you know, supremacy evo and all that
the only logical conclusion xD
fuck.
i have two of those spare , do you live in Germany ?
Close.. I live in Denmark. Could we work something out? That would be real neat with the new witcher expansion coming up I dont want my CPU throttling!
Well, i fucked up names, i have 2 dcp 2.2
Im sorry,this one is free :D
But you have to deal with that.
So you would need to fix that with something else then hotsnot and zipties.
If you want, ill send it to you.
Dead pump or air in the system?
Awesome!
Yeah I think it'll be enough I only have 1 rad and cpu block.
I'll message you.
If so how would I be able to tell / fix it?
