i removed my processor from the socket and checked out there was some kind of melted plastic in between the golden pins i tried to remove it wih brush but it didnot come out
i have fx 8350
i have fx 8350
Was there a problem before you removed the chip? It's probably just thermal compound. If so you can use this to remove it. Just make sure you follow the instructions! http://www.crcindustries.com/ei/product_detail.aspx?id=05101
nope there was not a problem i removed the cheap to change the cooler
but it does not looks like thermal paste to me
when i removed it it wasnt there but after a few days when i looked at my cpu again then i noticed it
i runned the processor its working fine but hangs sometime now should i worrey ?
When you removed it where did you store it? It could be anything. Having stuff stuck between your pins, especially a conductive material, means things aren't going to end too well!
my system is running for an a hour now so i do not think its conductive
+ i kept it in the mobo socket so i do not know what it is
+ thermal paste was grey and the thing on cpu is white so i know its not thermal paste
