Is my PC rig overclockable?
Hey guys, I was wondering is my PC rig overclockable? If not, can you guys please show me which parts that I can upgrade on?
PC rig:
CPU: Intel Core i5-3570k
MOBO: ASUS P8Z77--V LX2
Video Card: SAPPHIRE RADEON HD 7850 OC 2GB
RAM: G-SKILL RIPJAWS-X 8GB
Power Supply: Cooler Master M2 Silent Pro 520W
CPU Cooler: Cooler Master Hyper 212 EVO
Hard Drive: Seagate Barracuda 500GB
OS: Windows 8 OEM (64-bit)
Case: Cooler Master Silencio 550
Optical Drive: Just some random cheapass DVD drive
I'm still kinda new about the whole overclocking thing but I am learning. Gonna start somewhere. Right?
That build is definitely overclockable. The Hyper 212 Evo can handle a mild overclock (like 4.0 - 4.1gHz) without approaching high temps. If you want to go higher, a bettere air cooler is necessary. If you want the most out of it, a custom loop is required. Don't think that you need a custom loop, though. I recommend getting a Phanteks PH-TC14PE or a Swiftech H220 when it comes out. The H220 is very good - practically a custom loop that is just pre-assembled.
yeah that would be ok for mild overclocking, im not sure youd want to go much more than that with a 520Watt PSU, under heavy loads for the cpu and gpu it "might" start to struggle.
