I recently OC'd my FX-6300 to 4.2GHz I ran prime95 for about 3 hours without any cores failing. The only problem I've had was one lock up on Crysis 3 maxed out. After playing for about 5 hours straight, but haven't had one hiccup since. My question is in Asus Probe II I noticed this today...
[09/19/2013 at 01:32 pm] +12V 7.104 Abnormal [09/19/2013 at 01:32 pm] +12V 12.046 Normal [09/19/2013 at 01:54 pm] +12V 0.360 Abnormal [09/19/2013 at 01:55 pm] +12V 12.046 Normal
Sorry people I had a long week, and weekend, but anyways... I'll download hwinfo thanks cooperman. Sapere my whole computer stats is in my profile just click my name. I constantly run HWMonitor my CPU sits at 27c at idle, running games like Crysis for hours it usually never gets hotter then 40c. I also probably should have mention this is my first OC. I don't remember all the settings after I finished the OC if you need those I can get them, cause I may have fudged that up too...
sold parts are guaranteed to run stable @ spec on box when they're within temperature parameters. If he has a bad piece of silicon it may not get past that 4.2
