Pictures of the problem. https://imgur.com/a/D5rxNbC
My PC Specs.
CPU: AMD Ryzen 7 1800X 3.6 GHz 8-Core Processor @ 3.7 Ghz
Motherboard: MSI X370 XPOWER GAMING TITANIUM ATX AM4 Motherboard
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3200 CL16 Memory @ 2666 Mhz (max due to stability)
Video Card: EVGA GeForce GTX 1080 Ti 11 GB FTW3 ELITE GAMING WHITE Video Card
Power Supply: Corsair RMx 850 W 80+ Gold Certified Fully Modular ATX Power Supply
About a year ago I started getting some weird freezes while playing games, they would happen about once every 1-2 months, then about once a month, now they are happening almost every time I play a game. Sometimes my GPU is at 95% sometimes its only at 60%. CPU is never maxed.
Right before the whole PC freezes, I can hear people still talking on discord but my mic cuts out instantly. I can usually hear the people talking for about 10-15 seconds before the full freeze happens.
Also, if I alt-f4 as soon as the pixelization happens I can exit the game and the PC won’t freeze, it will just hang for about 3-5 seconds then it will play all the other inputs I did during the hang. I can also “alt+ctrl+dele” to avoid the PC from freezing and needing to be restarted.
Things I have tried to correct this issue in roughly the order I have done them.
- Lower my power limit to 90% and my core and mem clock by -100mhz on the GPU using MSI afterburner
- Updated the GPU drivers thru NVidea GeForce Experience.
- Updated Windows.
- Reseated GPU and all RAM DIMMs
- Moved my games to a new SSD with a new SATA cable.
This didn’t work so today I this, in this order.
- Updated Windows and use O&O shut up to disable telemetry and disable Cortana.
- Ran MemTest86 Free (3 passes w/ all tests no errors)
- Updated all Motherboard drivers through MSI website
- Updated Motherboard BIOS thought MSI website
- Ran RYZEN Master (trying to look for any CPU drivers)
- Checked for any RAM drivers (couldn’t find anything)
- Uninstalled NVidea GeForce and all Video drivers using Guru3d DDU
- Installed GPU drivers using TinyNvidiaUpdateChecker
Still the problem persists. In the past I have used:
- simplewall as network manager
- https://old.reddit.com/r/TronScript/ to clean up my PC
- https://github.com/Sycnex/Windows10Debloater and O&O shutup to debloat windows.
- Malwarebytes and Spybot for general AV and clean up.
I was going to reduce my CPU clock back to 3.6 and try to push my RAM closer to 3600 but I don’t know what else to do.
Any help would be appreciated.
Using event viewer I can see I usually get these types of error messages right before freezing.
Log Name: System
Source: nvlddmkm
Date: 9/18/2020 6:55:04 PM
Event ID: 14
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP-US8D59M
Description:
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video3
0a97(2c24) 0502b09c ffffffed
The message resource is present but the message was not found in the message table
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="nvlddmkm" />
<EventID Qualifiers="49322">14</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-09-18T22:55:04.8335128Z" />
<EventRecordID>3191</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="14348" />
<Channel>System</Channel>
<Computer>DESKTOP-US8D59M</Computer>
<Security />
</System>
<EventData>
<Data>\Device\Video3</Data>
<Data>0a97(2c24) 0502b09c ffffffed</Data>
<Binary>0000000002003000000000000E00AAC0000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Log Name: System
Source: nvlddmkm
Event ID: 13
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
The description for Event ID 13 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
\Device\Video3
Graphics Exception: ESR 0x405840=0xa0040200
Event Xml:
<System>
<EventID Qualifiers="49322">13</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2020-09-18T22:55:04.8150892Z" />
<EventRecordID>3190</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8948" />
<Security />
</System>
<EventData>
<Data>Graphics Exception: ESR 0x405840=0xa0040200</Data>
<Binary>0000000002003000000000000D00AAC0000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Log Name: System
Source: nvlddmkm
Event ID: 13
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
\Device\Video3
Graphics Exception: Shader Program Header 18 Error
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<EventRecordID>3189</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>Graphics Exception: Shader Program Header 18 Error</Data>
</EventData>
</Event>
Log Name: System
Source: nvlddmkm
Event ID: 13
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
\Device\Video3
Graphics Exception: Shader Program Header 9 Error
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<EventRecordID>3188</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>Graphics Exception: Shader Program Header 9 Error</Data>
</EventData>
</Event>
Log Name: System
Source: nvlddmkm
Event ID: 13
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
\Device\Video3
Graphics Exception: ESR 0x405848=0x80000000
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<EventRecordID>3187</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>Graphics Exception: ESR 0x405848=0x80000000</Data>
</EventData>
</Event>
Log Name: System
Source: Microsoft-Windows-DistributedCOM
Date: 9/18/2020 6:51:01 PM
Event ID: 10016
Task Category: None
Level: Warning
Keywords: Classic
User: DESKTOP-US8D59M\MagCyan
Description:
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
and APPID
{15C20B67-12E7-4BB6-92BB-7AFF07997402}
to the user DESKTOP-US8D59M\MagCyan SID (S-1-5-21-2749574402-971606426-143783166-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Event Xml:
<System>
<Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
<EventID Qualifiers="0">10016</EventID>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2020-09-18T22:51:01.9767608Z" />
<EventRecordID>3186</EventRecordID>
<Correlation ActivityID="{f5b827d7-f6e3-4f6a-b242-b0ab8ffe75a4}" />
<Execution ProcessID="1112" ThreadID="464" />
<Security UserID="S-1-5-21-2749574402-971606426-143783166-1001" />
</System>
<EventData>
<Data Name="param1">application-specific</Data>
<Data Name="param2">Local</Data>
<Data Name="param3">Activation</Data>
<Data Name="param4">{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}</Data>
<Data Name="param5">{15C20B67-12E7-4BB6-92BB-7AFF07997402}</Data>
<Data Name="param6">DESKTOP-US8D59M</Data>
<Data Name="param7">MagCyan</Data>
<Data Name="param8">S-1-5-21-2749574402-971606426-143783166-1001</Data>
<Data Name="param9">LocalHost (Using LRPC)</Data>
<Data Name="param10">Unavailable</Data>
<Data Name="param11">Unavailable</Data>
</EventData>
</Event>
Log Name: System
Date: 9/18/2020 6:43:36 PM
Event ID: 10016
Task Category: None
Level: Warning
Keywords: Classic
Description:
and APPID
Event Xml:
<System>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2020-09-18T22:43:36.2487451Z" />
<EventRecordID>3185</EventRecordID>
<Correlation ActivityID="{27fa7e39-3a78-422f-90ad-2584c3bf5839}" />
<Execution ProcessID="1112" ThreadID="1528" />
</System>
<EventData>
</EventData>
</Event>
Log Name: System
Date: 9/18/2020 6:43:00 PM
Event ID: 10016
Task Category: None
Level: Warning
Keywords: Classic
Description:
and APPID
Event Xml:
<System>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2020-09-18T22:43:00.7483511Z" />
<EventRecordID>3184</EventRecordID>
<Correlation ActivityID="{34f2bb4a-d4ef-431c-a909-c406847538d5}" />
</System>
<EventData>
</EventData>
</Event>
