So, I’ve had this error that I’ve been fighting all day. Its an error I had a few months ago that I fixed (dont recall how) and now this is my temp solution. Tech specs are listed at the bottom.
So after about 1-2 minutes in Rainbow Six Siege my game would freeze and crash and my event viewer would show this; (note that temps were fine during all of this, this isn’t temp related)
I could also create this error after 5-10 minute in Heaven benchmark.
To try and fix it I did the following;
Compete reinstall of Windows 10
Trying to reinstall drivers
Try installing older drivers
Purge drivers with DDU and reinstall fresh
Disable Xbox DVR
Disable Windows Driver installs via Windows update
Running game as admin/ compatibility mode
Disabling Full-screen enhancements
Changing windows power options to max performance and disable link state power management
Lowering the clock speed and mem clock speed by 100 Mhz
Just kidding its doing it again.
Is my GPU just dying? Any advice?
i7 5820K with NZXT Kraken X61 Cooler (no overclock)
EVGA 1080ti
SuperNOVA 850 G2 850W
ASUS X99-A/USB 3.1
16 GB Corsair Vengeance RAM
I tend to see GPUs fail more spectacurlarly than this. Bad artifacting in games, blue screen, complete driver crash followed by black screen, or no display at all.
Have you tried installing a different version of Windows, 8.1 for example?
Nah, you’re good, lol. You shouldn’t have any real performance hit with moving it. But you may want to look into a new motherboard soon. Your PCI slot may be damaged if that really does solve it.
Maybe you could try to update the motherboard bios.
Could be an issue with either the card or the board,
or it could be a software issue.
Because windows10 installs updates on itself.
So yeah maybe MS broke something again…
