This is it
http://pcpartpicker.com/user/Rbexpert/saved/1xls
Thank you guys in advance
This is it
Yes however I would consider saving yourself $100 and pirating/downloading the OS and getting rid of that CD drive and install it via USB!
enjoy $100 in your pocket or spend it more elsewhere
Thanks Mitchy!
Anyone really, I would like to save the 100 dollars and install it via usb, but where would I download it?
Well you can easily download a free OS like Ubuntu
or there are many sites where you can pirate windows via torrenting
If I could ask, would someone link me a windows 7 64 bit download not as a torrent?
79-mother loving-70. A 7970 is going to be much better than a 2GB 680 in the long-run. It will give you the option to mine BTCs and actually profit from your computer. Hell, if you pirate Windows, then you could get 7950 Crossfire, which will outperform both options.
