Is my card overkill for the resolution im running?
I have a 270x@1200mhz and my operating resolution is 1440x900.
Whats your opinion?
EDIT : Wrong PU forum , plz move to gpu if possible.
Nope. And it will be okay if you upgrade to 1080. I gamed on 900 for a while. It worked fine on my 7870. It is probably a little over powered but nothing crazy and the alternative is going with an underpowered card. This is about right.
Edit: the OC might be a bit unnecessary but hey oc is fun.
I like ocing cards :D
Cpus not that much.
