Is my build good?
http://pcpartpicker.com/user/dragonblaze547/saved/2GdgXL
Good Specs or Not? Suggestions to improve. I will get more ram in the future.
It's not bad, the 760 isn't a bad gpu, but not  the greatest. Do you have a specific budget and what are you planning to do with this computer?
Why would you skimp on RAM if you're building a gaming PC?
My suggestion:
Get an i5-4570, 8gigs of RAM, no aftermarket cooler and a decent Z97 for under $100 to give yourself room for future upgrades like an unlocked i7. Something like MSI Z97 PC Mate which is like $80. It fits the budget that you seem to have and you'll get a lot more gaming performance, a lot less heat and power consumption. You lose on overclocking ability, but honestly, overclocking isn't that big of a deal. This i5 is still not gonna struggle with anything you throw at it for years.
Bit weak on the GPU and RAM.
I just wanna play minecraft and bf4 at the moment. My budget is like under 800
I wanna play bf4 and minecraft on at least high settings. Budget is under 800
id wait for the 960, if you can wait a week?
