Heres a link http://pcpartpicker.com/p/3aEpK
Get 8gb's of ram and then your good :)
http://pcpartpicker.com/p/3eas0
Yay
http://pcpartpicker.com/p/3ebNM
It's basically the same as Some Tech Noob's, but I added a 270x. For a few bucks more than that 660, you can get better performance.
Also, the Source 210 (the case I recommended) is a good case, but it only comes with one fan, so I'd recommend grabbing another 120mm and putting it in the front. The NZXT fans that would match the case are only ~10, and I'd recommend the Prolimatech Blue Vortex's as a good, cheap, quiet fan if you don't care about the color matching.
Thanka guys :)
