Is it possible to run two routers in a network?
Hello forums, I want to add another router to my network, specifically a pf sense that I will be building. I have a couple of questions, and I want to make sure that the PC hardware for the pf sense will be worth my time.
Current router: D-Link DIR-825
Current Modem: Motorola Surfboard SB6121
Internet Connection:
The modem has a Cable/DSL connection from the ISP, and an Ethernet cable going into my router.
The plan:
I was planning on recycling an old PC into a pf sense router. Here are the specs -
CPU: AMD Sempron 3100+, 1.8 ghz, 256 kb L2 cache, 1600 mhz system bus.
RAM: 1 gb DDR memory.
On-board networking: 10/100 mbps Ethernet port.
Misc: 56K ITU V.92 modem, Linksys Wireless G 2.4 ghz PCI card, Linksys Wireless G USB adapter - WUSB54GSC, D-LINK DI-514 2.4 ghz router (Extra I have laying around. Not compatible with DD-WRT, or other firmwares to my knowledge).
HDD's: x1 - 60 gb IDE, x2 30 gb IDE, x2 320 gb 2.5" SATA.
I also want to build a remote torrent machine that I can access from my laptop to download and stream anything I want. I am simply mentioning this just in case it throws a wrench in the works.
My questions:
 - Can I use an Ethernet switch to connect my modem, D-Link router, and pf sense router and have the network fully functional or should I replace the D-Link with the pf sense router?
 - Should I invest in better hardware for the pf sense (gigabit ethernet, non-ide hdd's, dual band PCI card/USB adapter for broadcasting WiFi, Bluetooth)?
 - Does the current hardware look to be enough for gaming, large amounts of torrent traffic, and bandwidth for 10 wireless devices, and 4 wired devices?
Thank you for your time, and patience with this networking noob. I hope that I can get a kick-ass network up and running soon thanks to your help!  :)
No. A modem will only talk with one device as they are setup with an IP subnet of /30 (255.255.255.252).
If the switch were another router, then yes you could link two other routers to that one.
Depends what you need. Your internet speed isn't fast enough for you to see any benefits from moving to gigabit. However if you have a media server that will placed on another NIC on the router, then you may wish to invest in it. If it would be connected to the switch, then no.
With the HDDs, are you intending on using caching. If so, the faster the better. With IDEs you aren't really going to notice any difference of moving to something faster, because they will still read faster than that of your ISP connection.
As for wireless cards. I wouldn't. With PFSense you are best to use a seperate wifi access point connected to the router. The wireless support built into PFSense is a little spotty and can be annoying and temperamental.
Bluetooth? `: / in a router? You crazy!
It meets minimum requirements. However it is very old hardware. the only way to tell is to test it and find out.
  1. I wouldn't recommend the switch, just connect the modem to the PFSense box using the WAN port you assigned.
  2. The hardware is all fine. I do want to point out that you don't need all the hard drives in the PFSense Box. Build a file server for all the torrenting with the extra hard drives. Don't worry about getting any cards for the PFSense Box, as Zang mentioned you are better off with a dedicated WAP (WAP=FAP). You can use your D-Link Router for that along side for the switch. Though I would recommend getting a dedicated switch to plug into the assigned LAN port.
    The way I have it setup on my network is my modem is plugged into the WAN port, then I have my Belkin 8 port switch connected to the LAN port. Then my wireless access point plugged into that. When you plug your D-Link router for the AP, use the LAN port and disable DHCP on it.
  3. The hardware is plenty capable of all of that, I put my PFSense Box through hell. If I remember right, a CPU that is a single core at 2Ghz is capable of processing around 150-200mbps throughput, so you are covered there.
I don't want to thread-jack, but I have a related question that doesn't warrant a new thread. I'm getting suuuuper frustrated with my current setup. I'm living in an apartment that only allows Charter internet and cable. I've got Charter's crap modem into my roommate's old b/g Linksys router. I've been having trouble even loading web pages lately. I don't think it's the router's fault entirely, but I'm tired of sharing a network with others. I propose this: I go get a personal router for my own network that I can play with. How should I go about setting this up? Cat5 from roommate's router's LAN port into my own router's WAN port? Should I start my own thread? Should I have pasta for dinner?
You do have the option to buy your own modem, just need to make sure it is supported by charter. You could probably get a separate internet connection to. I would just say, overhaul your network, which I can help you with.
YES EAT PASTA!
http://www.dslreports.com/shownews/Charter-Stops-Supporting-Customer-Owned-Modems-120059
I read this and prepared to return the Motorola SB6121 I just bought. I was thinking maybe getting a switch to put between the modem and the router so I can just use a wired connection. Never done networking before, so I don't know for sure. AND I'M GONNA MAKE SOME PASTA!
I talked to my friend Lucas. He said you can use your own modem. He is with Charter.
