I was [email protected] and decided to check my gpu temp to make sure it was very high because folding isn't supposed to take up that many resources. Well, when I looked I saw it went from 43C to 68C. I made the fan run at 100% to try to keep it cool. The lowest it has gone when folding is 62C. I have 2 questions:
Can running a fan at 100% damage it?
Is 68C to high for a gpu temp?
Also, I have an EVGA 9800 with dual slot cooling so its supposed to get good airflow.
The fan will eventually bug out on you after a few years at 100% I'm talking about like 5-10 years though. By then you've probably upgraded to a better and cooler card anyways.
I have my 9800GTX+ overclocked and running at 100% fan during gaming and I hit reset when I'm just browsing around.
