In most build video they recommend you do a pre-build boot to make sure everything is working,
is it safe, once you're in the bios, to turn the power off to build the pc in the case?
in Bios, everything is saved into the CMOS only if you tell it to (by hitting f10 for instance). By just looking at a bios screen everything is basicly in an idle state.
By powering off while in BIOS, essentially, almost nothing can go wrong.
thanks
