My exact build on ibuypower is about $50 more expensive, should I spend it so I don't have to build it myself or just save my money and build it?
ibuypower sucks dont use their builds use the builds from logan they are a lot better
What is your budget? and what is the specs your looking at building your pc to?
And what will you be useing it for?
save your money you will have a sense of accomplishment and it is cheaper
The magic of it all is in buidling the PC. You wouldn't feel a sense of accomplishment and pride and you wouldn't value it as much if you didn't build it.
waste, even some of the less talented people on here could make a better build than them
