Is a 1080p monitor really necessary?
I have a relatively beefy rig and since XMAS is around the corner it means I get some cash to spend and I am in a dilemma between a nice LG 1080p IPS monitor or a 2DS (because I'm bored shitless of the games coming out) with Zelda. If you were in my shoes what would you get I currently run a 7870 and i5 3450 @3.7ghz on a 1360x768 monitor.
7870 is a really great card for 1080p. You can grab a 1080p for as little as $100, or near. I think it is worth the cost, and you can keep your current monitor as a second screen for convenience.
Legend of Zelda Ocarina of time? You could always download Project64 and then get the OoT ROM and play on your computer.
I was talking about A link Between worlds but I also want more games of course however ATM gaming bores me until Dark Souls II comes out.
Asking if 1080p is necessary is just like asking if Gaming is necessary.
Higher resolution always looks nicer, but you might want to wait until the consumer version of the oculus rift virtual reality goggles are tested. If the rift pans out, you would probably be better off spending money on that, than on an incremental resolution improvement.
Your computer specs are sufficient to render all current games at 1080p
> ...2DS (because I'm bored shitless of the games coming out) with Zelda.
I don't know what that means, 2ds is a Nintendo handheld right?, why would that even be in the same category than a monitor ?
If you are bored with computer games, maybe you need more variety in your life, try reducing game-time & do some different for a while.
Or a 2DS. Yes. I'm in a Dilemma because I'm really bored of gaming at the moment and only have a certain budget either resulting in a handheld (2DS or Vita etc) or a 1080p monitor.
Your profile says you have a 1600 x 900 monitor so basically your comment just collapsed in on itself.
I haven't updated that in quite a while.
And my point is that it is only necessary if you think it is. If you don't want it, then you don't need it. I personally like 1080p, but Im going to be getting a 1440p monitor soon.
Thanks for being a dick about it, though. Hadn't had my daily dose yet.
Lol your comment wasn't clear it looked like you aren't a gamer if you don't have a 1080p monitor. Sorry for for the misunderstanding. I'm gonna be getting a 1080p monitor hoping that I won't be disappointing. Thanks for your help.
Damn it. I wanted to give Phantom his daily dose of dick!
Anyway, I didn't properly read your question. The best solution would probably be a 2DS now, and then save for whatever monitor you desire in the future. You might skip 1080p altogether and get a 1440p or 4k panel.
Hmmm good Idea I'll have to think about it even more. I just feel the jump to 1080p from where I'm at isn't worth the money as well I don't play any demanding games anyways. Unless GMOD, CS, Black Mesa Source, Dark Souls and Quake 3 are demanding in your eyes.
You really don't need HD resolutions for those games.
I think the obvious choice would be the 2DS. Even if you could utilise a 1080p monitor, it would be better to have two things to enjoy, instead of one platform. Like I said before, you can grab a higher res panel at a later time.
1080p let alone anything higher will drastically increase your game immersion to the point of wanting to try more games. Worked for me anyways.
1080p is double the pizels of your current monitor. DOUBLE. your current monitor is 1million pixels. 1080p is 2million....
do you want a monitor with double pixels that make images look better?
do you want a monitor that can play blurays at their native 1080p resolution?
if you answered yes to either of those, then get a new monitor. if you want a good gaming monitor, try this one. uber low input lag. it is used exclusively in the EVO fighting game championship tournament due to the low input lag.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117
(technically, the VH236H is the evo monitol. the VH238H is the same panel as the VH236H, except it is LED backlit)
Personally... yes. If you use your PC for anything more than gaming, 1080p is better. Graphically, you will take a hit in many games for the bigger resolution though. Although the better PC experience in general may make it worthwhile.
2DS/3DS is your choice. I'd only have one for Zelda and possibly Pokemon. For those two games, I wouldn't waste my money.
Well if you are bored with gaming why are you investing money in it. I assume you don't need a new monitor for other tasks & a gaming hand-held is still gaming, is it not.
I get the impression that you want to buy new equipment to make gaming seem less boring for you. New gizmo's won't change how you feel.
In my experience, when ever a hobby of mine gets boring, i stop doing it for a while, and afterwards it feels fresh again.
Money doesn't spoil, you don't have to spend it right away.
Phrasing....
In my experience when you combine higher pixel density with larger screen size, it's a winning combo in terms of an upgrade.  Plus the extra resolution is great for multitasking.  I personally prefer 1920x1200 (1200p if yo must...) as far as aspect ratio goes, but yes.  A decent 1080p monitor would likely be a good upgrade for you.
As far as the 2DS, your call.  I've never touched one so I can't really offer an opinion.  If you enjoy the games offered, form factor and play style, then go for it.  The thing is though, a lot of people get a portable gaming device and realize that they hardly use it.  Many view them as redundant since most smart phones can handle games well enough to fill that gaming need when you are out and about, and it's already with you.  The 2DS is just something else to carry, and only has one use.  Just something to keep in mind.
