Is 60hz Enough?
I had recently gotten a BenQ 22" GW2255 for my new gaming rig. Is 60hz enough for gaming, or should I sell it and upgrade?
Is 60hz enough for gaming?
Yes, unless you play competitive CS.
A lot of people cant tell the difference. There is a video of Linus trying to do it, but he doesn't do so well.
Once you have been shown the difference between 60Hz and 120Hz, you will always recognise it. However, I am happy to stick to 60Hz panels because the quality of those panels is much higher. e.g 1440p panels or 1080p IPS panels. Much wider use, better colours, and therefore, more visually pleasing.
is 120/144hz better, of course, can many people see a difference, yes, is 60 more than fine for most people, also yes
