Hi all,
I’ve done my due diligence (a couple of hours of googling) and I can’t really get to a point where I can even start to understand what to do here.
I need to implement some QOS/bandwidth limiting on a local machine.
The quest if to have the following:
10...* (local network) - full speed
anything else in or out (internet) - 400kbps max.
I know this would be easier on the router but it’s locked down and supported by the ISP so I can’t touch it. Also putting another box inbetween is overkill.
Any ideas on what to do?
Thanks
