I am not really sure where to post this but for some reason me or any of my friends could not ping my home external ip
I am doing this because I am trying to remote desktop to my home pc.
any response would be nice
thanks
thanks
You will have to go in to your rougher settings and turn on WAN ping respond. by default it is off so people cant ip flood you or do outher stuff. But you should not need to turn this on to do remote desktop stuff.
thanks for the quick response
Putting on the ping won't give you much. Also its better not to respond to WAN ping for obvious reasons.
To enable remote desktop through the router, you will have to forward the port to your PC sitting in the lan.
Let's get down to it, shall we? Are you talking about RDP?
when i opened up the wan ping then other people can ping my router
it is already ready forwarded
.. But... Why is this ping necessary m8?
because before people could not even ping it let alone remote desktop and now they can
Okay, well I'm glad its solved then, But now, I want to understand:
A ping is a ICMP TCP request used to check if something is "online". It is not a needed step in setting up a RDP session...?
By responding to PINGs on the internet, you are letting everyone know you are 'online', and as mentioned above, you can now be flooded since your router is forced to respond.
Sorry to insist, but I would advice you to refrain from that...
I have advise not to enable ping respond. like i said earlier its a bad idea, and should not be needed for any remote desktop. I host some TF2 servers and a small web server for messing around and i have not turned on ping respond. if you can tell me what RDP you are running i am intrested to try it out to see if i have to turn on ping respond.
If it's Mincrosoft supplied Windows Remote Desktop then I've used it in the past with a few different people on different networks and routers all without needing any special rulings in the router configuration, nor any modifications in the firewall(s) settings. Perhaps you have a firewall issue?
