So i’ve tried to enable the iommu kernel flag and getting a freeze when my display manager starts. I’m using Manjaro KDE with kernel 4.19.16. Using a GTX 970 and a GTX 660 however with only the 970 in i still get the same issue. Processor definitely supports VT-D i7-3770. I tried changing X session with ctrl+alt+f2, that doesn’t work at all when i get this freeze.
What is the easiest way to post the logs as i can’t upload files here yet? Is there a preferred site? Here is a snippet of the last bit of logs during a failed bootup with the IOMMU flag.
Jan 27 01:33:23 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=grub-boot-indeterminate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:23 TheSwarm audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=grub-boot-indeterminate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:23 TheSwarm systemd[1]: Reached target Offline System Update (Pre).
Jan 27 01:33:23 TheSwarm avahi-daemon[424]: Successfully dropped root privileges.
Jan 27 01:33:23 TheSwarm avahi-daemon[424]: avahi-daemon 0.7 starting up.
Jan 27 01:33:23 TheSwarm dbus-daemon[428]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.4' (uid=0 pid=426 comm="/usr/bin/ModemManager ")
Jan 27 01:33:23 TheSwarm avahi-daemon[424]: Successfully called chroot().
Jan 27 01:33:23 TheSwarm avahi-daemon[424]: Successfully dropped remaining capabilities.
Jan 27 01:33:23 TheSwarm systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Jan 27 01:33:23 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:23 TheSwarm avahi-daemon[424]: No service file found in /etc/avahi/services.
Jan 27 01:33:23 TheSwarm systemd[1]: Starting Authorization Manager...
Jan 27 01:33:23 TheSwarm avahi-daemon[424]: Network interface enumeration completed.
Jan 27 01:33:23 TheSwarm avahi-daemon[424]: Server startup complete. Host name is TheSwarm.local. Local service cookie is 3772681816.
Jan 27 01:33:23 TheSwarm polkitd[435]: Started polkitd version 0.116
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.7759] NetworkManager (version 1.14.5dev+17+gba83251bb-2) is starting... (for the first time)
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.7761] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Jan 27 01:33:23 TheSwarm kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input21
Jan 27 01:33:23 TheSwarm kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input22
Jan 27 01:33:23 TheSwarm kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input23
Jan 27 01:33:23 TheSwarm kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input24
Jan 27 01:33:23 TheSwarm systemd[1]: Started Network Manager.
Jan 27 01:33:23 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.7845] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jan 27 01:33:23 TheSwarm systemd[1]: Reached target Network.
Jan 27 01:33:23 TheSwarm systemd[1]: Starting Permit User Sessions...
Jan 27 01:33:23 TheSwarm systemd-udevd[327]: Process '/usr/bin/alsactl restore 1' failed with exit code 99.
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.7871] manager[0x55eae9638080]: monitoring kernel firmware directory '/lib/firmware'.
Jan 27 01:33:23 TheSwarm dbus-daemon[428]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.16' (uid=0 pid=429 comm="/usr/bin/NetworkManager --no-daemon ")
Jan 27 01:33:23 TheSwarm systemd[1]: Started Permit User Sessions.
Jan 27 01:33:23 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:23 TheSwarm systemd[1]: Starting Hostname Service...
Jan 27 01:33:23 TheSwarm polkitd[435]: Loading rules from directory /etc/polkit-1/rules.d
Jan 27 01:33:23 TheSwarm polkitd[435]: Loading rules from directory /usr/share/polkit-1/rules.d
Jan 27 01:33:23 TheSwarm polkitd[435]: Finished loading, compiling and executing 5 rules
Jan 27 01:33:23 TheSwarm dbus-daemon[428]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jan 27 01:33:23 TheSwarm systemd[1]: Started Authorization Manager.
Jan 27 01:33:23 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:23 TheSwarm polkitd[435]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jan 27 01:33:23 TheSwarm systemd[1]: Started Modem Manager.
Jan 27 01:33:23 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:23 TheSwarm dbus-daemon[428]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jan 27 01:33:23 TheSwarm systemd[1]: Started Hostname Service.
Jan 27 01:33:23 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:23 TheSwarm systemd-logind[427]: Watching system buttons on /dev/input/event2 (Logitech MX Master 2S)
Jan 27 01:33:23 TheSwarm systemd-logind[427]: Watching system buttons on /dev/input/event3 (Gaming KB Gaming KB )
Jan 27 01:33:23 TheSwarm systemd-logind[427]: Watching system buttons on /dev/input/event4 (Gaming KB Gaming KB System Control)
Jan 27 01:33:23 TheSwarm systemd-logind[427]: Watching system buttons on /dev/input/event5 (Gaming KB Gaming KB Consumer Control)
Jan 27 01:33:23 TheSwarm systemd-logind[427]: Watching system buttons on /dev/input/event6 (Gaming KB Gaming KB Keyboard)
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.9717] hostname: hostname: using hostnamed
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.9718] hostname: hostname changed from (none) to "TheSwarm"
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.9721] dns-mgr[0x55eae9642930]: init: dns=default, rc-manager=symlink
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.9724] manager[0x55eae9638080]: rfkill: WiFi hardware radio set enabled
Jan 27 01:33:23 TheSwarm NetworkManager[429]: <info> [1548570803.9725] manager[0x55eae9638080]: rfkill: WWAN hardware radio set enabled
Jan 27 01:33:23 TheSwarm dbus-daemon[428]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.16' (uid=0 pid=429 comm="/usr/bin/NetworkManager --no-daemon ")
Jan 27 01:33:23 TheSwarm systemd[1]: Starting Network Manager Script Dispatcher Service...
Jan 27 01:33:24 TheSwarm dbus-daemon[428]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jan 27 01:33:24 TheSwarm systemd[1]: Started Network Manager Script Dispatcher Service.
Jan 27 01:33:24 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0065] settings: Loaded settings plugin: NMSKeyfilePlugin (internal)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0077] settings: Loaded settings plugin: NMSIbftPlugin ("/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-2/libnm-settings-plugin-ibft.so")
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0095] manager: rfkill: WiFi enabled by radio killswitch; enabled by state file
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0096] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0098] manager: Networking is enabled by state file
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0100] dhcp-init: Using DHCP client 'internal'
Jan 27 01:33:24 TheSwarm nm-dispatcher[463]: req:1 'hostname': new request (0 scripts)
Jan 27 01:33:24 TheSwarm nm-dispatcher[463]: req:1 'hostname': completed: no scripts
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0135] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-2/libnm-device-plugin-ovs.so)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0147] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-2/libnm-device-plugin-adsl.so)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0179] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-2/libnm-device-plugin-wwan.so)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0215] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-2/libnm-device-plugin-bluetooth.so)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0234] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-2/libnm-device-plugin-wifi.so)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0353] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-2/libnm-device-plugin-team.so)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0368] device (lo): carrier: link connected
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0373] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0387] manager: (enp3s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0419] keyfile: add connection /var/run/NetworkManager/system-connections/Wired connection 1.nmconnection (8d35a815-bd57-3a75-9433-f863f52bba4c,"Wired connection 1")
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0437] settings: (enp3s0): created default wired connection 'Wired connection 1'
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.0445] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jan 27 01:33:24 TheSwarm kernel: IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
Jan 27 01:33:24 TheSwarm kernel: enp3s0: 0xffffa81d41a35000, 10:bf:48:83:5d:2f, IRQ 35
Jan 27 01:33:24 TheSwarm systemd[1]: Started Login Service.
Jan 27 01:33:24 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:24 TheSwarm systemd[1]: Reached target Multi-User System.
Jan 27 01:33:24 TheSwarm systemd[1]: Starting TLP system startup/shutdown...
Jan 27 01:33:24 TheSwarm systemd[1]: Started Simple Desktop Display Manager.
Jan 27 01:33:24 TheSwarm audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 27 01:33:24 TheSwarm systemd[1]: Reached target Graphical Interface.
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.1270] ovsdb: Could not connect: No such file or directory
Jan 27 01:33:24 TheSwarm NetworkManager[429]: <info> [1548570804.1284] modem-manager: ModemManager available
Jan 27 01:33:24 TheSwarm nm-dispatcher[463]: req:2 'connectivity-change': new request (0 scripts)
Jan 27 01:33:24 TheSwarm nm-dispatcher[463]: req:2 'connectivity-change': completed: no scripts
I’m using “intel_iommu=on” as the parameter to enable IOMMU. In the BIOS i enabled virtualization technology which is from what i understand Asus’ way of saying VT-X/VT-D.
