Internet Connection/ Gaming problem
So I've narrowed it down to this pc.
I pay nearly $100 a month for 60mbs down and 6up
but what the point if i get random drops amirite?
but it doesnt drop on my ps3, or other computer ONLY this one.
ive done dns flush, ive changed my primary and secondary. Problem still occurs.
is this a virus or something ? i only have avg free edition but ive always had it
Does anyone know a fix? and IF it is a virus that is known to someone out there, could you point me in the direction of a gamer friendly antivirus program.
To explain symptoms. Everything will run find for 30 minutes then cut out completly for about 10 seconds then come back again at full speed for maybe an hour. then repeat over n over.
Most of the time right at startup or when coming out of sleep mode itl be off for an extended time aswell.
now most the time when it happens it shows the yellow indicator on the lan icon on bottom (im hardlined) but when i look over at the modem all lights read normal. I feel it HAS to be on my pc's end.
can anyone help?
Does the computer have a statically assigned IP or just DNS. Are there any other programs that could be running in the background that utilise the network?
Have you checked your NIC drivers?
as far as i know it has a dynamic ip. but ive tried setting it to a static one. i think
not any programs that i can pinpoint. or that i WANT running.
Ive searched all my drivers and even did a driver checker thing and supposedly it updated all of them
I did a malware scan and these came up, Would these have caused my problems?
Registry Keys Detected: 8
HKCR\AppID\{D616A4A2-7B38-4DBC-9093-6FE7A4A21B17} (PUP.Optional.Wajam.A) -> Quarantined and deleted successfully.
HKCU\Software\1ClickDownload (PUP.Optional.1ClickDownload.A) -> Quarantined and deleted successfully.
HKCU\SOFTWARE\BI (PUP.Optional.FilesFrog.A) -> Quarantined and deleted successfully.
HKCU\SOFTWARE\INSTALLCORE (PUP.Optional.InstallCore.A) -> Quarantined and deleted successfully.
HKCU\SOFTWARE\SWEETIM (PUP.Optional.SweetIM.A) -> Quarantined and deleted successfully.
HKLM\SOFTWARE\Updater By SweetPacks (PUP.Optional.SweetPacks.A) -> Quarantined and deleted successfully.
HKLM\SOFTWARE\Wow6432Node\Updater By SweetPacks (PUP.Optional.SweetPacks.A) -> Quarantined and deleted successfully.
HKLM\SOFTWARE\SWEETIM (PUP.Optional.SweetIM.A) -> Quarantined and deleted successfully.
Registry Values Detected: 6
HKLM\SOFTWARE\Mozilla\Firefox\Extensions\{7D4F1959-3F72-49d5-8E59-F02F8AA6815D} (PUP.Optional.SweetPacks.A) -> Data: -> Quarantined and deleted successfully.
HKLM\SOFTWARE\Mozilla\Firefox\Extensions|{7D4F1959-3F72-49d5-8E59-F02F8AA6815D} (PUP.Optional.SweetPacks.A) -> Data: C:\Program Files\Updater By SweetPacks\Firefox -> Quarantined and deleted successfully.
HKCU\Software\BI|ui_path_filesfrog (PUP.Optional.FilesFrog.A) -> Data: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\FilesFrog Update Checker -> Quarantined and deleted successfully.
HKCU\Software\InstallCore|tb (PUP.Optional.InstallCore.A) -> Data: 0I1R2Q0U1F1E -> Quarantined and deleted successfully.
HKCU\Software\SweetIM|simapp_id (PUP.Optional.SweetIM.A) -> Data: {36338061-D6CA-11E2-8D10-60A44C2FFE79} -> Quarantined and deleted successfully.
HKLM\Software\SweetIM|simapp_id (PUP.Optional.SweetIM.A) -> Data: {36338061-D6CA-11E2-8D10-60A44C2FFE79} -> Quarantined and deleted successfully.
Registry Data Items Detected: 2
HKCU\SOFTWARE\Microsoft\Internet Explorer\Main|Start Page (PUP.Optional.Conduit) -> Bad: (http://search.conduit.com?SearchSource=10&CUI=UN21247613522761614&UM=2&ctid=CT3282812) Good: (http://www.google.com) -> Quarantined and repaired successfully.
HKLM\SOFTWARE\Microsoft\Internet Explorer\Main|Start Page (PUP.Optional.SweetPacks) -> Bad: (http://start.sweetpacks.com/?src=10&st=12&crg=3.5000006.10042&barid={36338061-D6CA-11E2-8D10-60A44C2FFE79}) Good: (http://www.google.com) -> Quarantined and repaired successfully.
Folders Detected: 2
C:\Windows\System32\WNLT\Installation (PUP.Optional.InstallBrain.A) -> Quarantined and deleted successfully.
C:\Windows\SysWOW64\WNLT\Installation (PUP.Optional.InstallBrain.A) -> Quarantined and deleted successfully.
Files Detected: 1
C:\Users\Jesse\AppData\Local\Bundled software uninstaller\biclient.exe (PUP.Optional.Somoto.A) -> Quarantined and deleted successfully.
(end)
