Intel(R) 82579V Gigabit Network Connection
Hey guys
I'm using a MSI Z77A-GD65 and i have a strange issue i check my Event Viewer in Windows 7 and i'm getting this Warning message and its telling me that Intel(R) 82579V Gigabit Network Connection, Network link is disconnected. and the same in the UEFI i have muck around with the settings in Windows and no luck strange thing is i'm connected to the internet tho, can anyone tell me is the issue with intel or MSI i don't think its a MSI issue.
Thanks all
Make sure your NIC driver is up to date - http://www.intel.com/p/en_US/support/detect
  1. Update the UEFI
  2. Update Driver
  3. Disable other NICS
Yes, i'm using the latest version
Thanks
I'm using the latest UEFI and same for the NIC
Thanks
Sometimes in the UFEI it will say Connected but most of the time says Disconnected, is it common for the intel NIC to show up on the UFEI
I might have it worked worked out i loaded up the UEFI and i enable the Network Stack which for some reason it was disable bye default so once i enabled it, now it shows a Connected.
