That being the case, did you really need to apply the patches to hyper-visor layer? If you control that and all the VM’s then the risk is minimal. Meltdown is a huge risk to public cloud providers not home users where you control the entire stack. Can you uninstall the patches?
Class actions like this should result in full compensation. Unfortunately lawyers end up with all the money. Hopefully we’ll soon be replacing them with robots.
Yeah, I could probably spend some of my valuable time tuning the VMs and doing security audits of the software running in them… But that has a huge cost as well. And it’s still Intel’s fault.
Intel started negotiating. They asked for details of the workloads so that their engineering staff could look into it. Waiting for a reply.
I agree about class actions, I prefer an individual action at Small Claims Court.
Intel suggested that I run without any patches / microcode updates if performance is an issue. I told them I would only do that if they insured me against Meltdown related security issues and optionally paid for security software and my time to evaluate it.
They have until February 10th to rectify this fault.
I should say that the PC was a Threadripper. Not cheap and a big upgrade over the Intel I had. I could have replaced my workstation and server with equivalent AMD machines, but decided instead to throw in some of my own cash and upgrade.
So assuming even a low price of $500 per unit, that’s still 600k, which is way out of the small-claims range for the US, however, OP is from the EU and @thro is from Australia, so those numbers may differ significantly.
