Intel I350 incorrect PBA/Part number when using intels drivers on fedora 28
Hi all,
I am new to this forum so excuse me if my question is not in correct category.
I am having some strange issue with my system:
mother board: z10pe 16d ws
network adapter: Intel I350-T4 PCI-Express PCI-E 4 Ports Gigabit RJ45 Server Adapter NIC
Latest bios with enabled intel vt-d, sr-iov
Os: Fedora 28 latest kernel
I was trying to make sr-iov working with this card since according to the documentation it was supported with this adapter. I try with the default igb driver but with no success. No errors were shown in the dmesg but virtual functions were not spawn (I have enable all relevant kernel flags).
Then i try to install latest intel igb driver and try again. This time i get this error:
[ 2036.218174] dca service started, version 1.12.1
[ 2036.226010] Intel® Gigabit Ethernet Linux Driver - version 5.3.5.18
[ 2036.226012] Copyright© 2007 - 2018 Intel Corporation.
[ 2036.226876] igb: 0000:81:00.0: igb_validate_option: max_vfs - SR-IOV VF devices set to 4
[ 2036.226887] igb 0000:81:00.0: Failed to initialize SR-IOV virtualization
[ 2036.293142] igb 0000:81:00.0: added PHC on eth0
[ 2036.293145] igb 0000:81:00.0: Intel® Gigabit Ethernet Linux Driver
[ 2036.293149] igb 0000:81:00.0: eth0: (PCIe:5.0GT/s:Width x4)
[ 2036.293154] igb 0000:81:00.0 eth0: MAC: a0:36:9f:85:66:5c
[ 2036.293262] igb 0000:81:00.0: eth0: PBA No: E84075-004
[ 2036.293339] igb 0000:81:00.0: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 2036.293420] igb 0000:81:00.0: LRO is disabled
[ 2036.293423] igb 0000:81:00.0: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
[ 2036.301564] igb 0000:81:00.0 ens1f0: renamed from eth0
[ 2036.330529] IPv6: ADDRCONF(NETDEV_UP): ens1f0: link is not ready
[ 2036.373254] IPv6: ADDRCONF(NETDEV_UP): ens1f0: link is not ready
[ 2036.373905] igb 0000:81:00.1: added PHC on eth0
Now comes the interesting part: according to this output driver gets “PBA No: E84075-004”
This is the part number of i340 network adapter, the one I have have completely different serial number.
According to lspci:
lspci -vvvs 81:00.1
81:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
Subsystem: Intel Corporation Ethernet Server Adapter I350-T4
Physical Slot: 1
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR- Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin B routed to IRQ 83
NUMA node: 1
Region 0: Memory at fb300000 (32-bit, non-prefetchable) [size=512K]
Region 3: Memory at fb408000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: vfio-pci
Kernel modules: igb
I already have ports of my adapter assigned via pci passthrough to windows vm so checked the part number there and it again show E84075-004.
Can some one help me with steps to identify why it seems like the part number I see is incorrect?
