valtam
November 25, 2024, 4:11am
1
As the title states, my PCI-e card is running at 1000 Mb/s instead of 2.5Gb.
Kernel 6.8.0-49-generic (Ubuntu 24.04)
sudo ethtool enp49s0
Settings for enp49s0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
2500baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
2500baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
MDI-X: off (auto)
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
quilt
November 25, 2024, 3:09pm
2
Have you tried manually setting it to 2.5G using ethtool? It does show as advertised & supported so maybe that works.
valtam
November 26, 2024, 12:11am
3
Yes, I’ve tried setting the rate with ethtool, when I do, the network adapter goes offline and I have to reboot. Then it’s back to 1000Mb/s.
diizzy
November 26, 2024, 4:46am
4
What NIC, tried another cable (you probably need at least CAT6/6A) and/or direct connection to the other end?
valtam
November 26, 2024, 5:52am
5
NIC is in the title. Cable is Cat 6.
quilt
November 26, 2024, 10:17am
6
Yeah these nics (Intel 225 and 226) have their fair share of issues. I had some as well where it ate its own firmware. Which device do you have exactly? Check the manufacturer for possible firmware upgrades.
But these are known to have issues with negotiation and stability especially at 2.5Gb.
jode
November 27, 2024, 12:10am
7
What NIC is connected to the other end of the cable?
valtam
November 27, 2024, 4:16am
8
NIC is connected directly to a 2.5Gb 8 port unmanaged switch.
valtam
November 27, 2024, 4:17am
9
UPDATE: Appears the cable was at fault, I’ve since replaced it with a brand new shielded Cat6a and everything is working as expected. Thanks folks
