i want to replace my two aoc 27 inch ips panels with a single 40 inch 4k panel
just backed out of a fantastic deal on a wasabi mango uhd420 via amazon.com mostly because of the purchase process and because i am now uncertain as to if this will work at all
i am using a dell latitude e7450 laptop with a dock that has dp and supports dp 1.2 as far as i know
the gpu is an intel hd 5500, which, according to the dell site, support one 3840x2160 @ 60 hz
now i have read warnings that some of these monitors will not work with macbooks or laptops, is this true?
this will be used at my office desktop and possibly some photo edit after hours, not gaming
any feedback would be appreciated
i just don't want to go down the wrong path, waste time and money
got a laptop running a 4k 30hz monitor at home with a intel 4400. the cpu, monitor, and cable can all run 60hz but the port is 1.0 not 2.0 hdmi. check your ports man.
