I’m in need of a wifi 7 card for testing, so i have tried some options.
I have a AMD B650 with a M.2 E-key port onboard and a AMD X670 with a ASUS PCE-BE92BT PCI-E card.
The only thing working on the 2 PCs are the bluetooth. The BE200 is not discovered in device management on Windows 11.
I have tried changing Bios versions and drivers. Nothing works.
After failing to make this work, i found out that is a known issue. Known as in not mentioned on the ASUS product page or Intel’s
Has anyone found a work around? Who is to blame for this not working? Is it working on Linux?
Wendell please do your magic
