damn, that sucks mate. i have 4x 48GB in mine, worked first go.
I suspect that the board is damaged, even with 2 sticks it canât boot, the âWelcome to GRUBâ screen flashed for a second and then the machine shuts down as if I was holding the power button ( with loud click from PSU ), then it turns on and goes into BIOS, but at least the BIOS shows up, with 4 sticks it canât even do that, well I will just have to fight some more to get that SR-IOV ![]()
Are you trying to run XMP/200S boost? Because that rarely works with 4 dimms on consumer boards.
Nope, no XMP, it never worked for me with 4 sticks, but 4800/5200 Mhz works on the ASRock B760 board.
I have returned with good news ![]()
After about a month of fighting hardware issues I managed to get my 96GB of RAM AND SR-IOV to work ![]()
Long story short, I tried 3 Asus boards ( well during my experiments I ordered 4 but one of them arrived as z390, at least the seller was cool and returned my money immediately ):
- ROG Maximus Hero Z790
- Prime Z790-P
- ProArt Creator Z690
All of them failed to boot with 4 sticks of RAM, no matter what I did it just didnât happen. My old ASRock was able to use those 4 sticks at 5200MHz no problem, so that was the first major problem.
Then I discovered that the Z790 ROG Maximus Hero does not support SR-IOV, I had the exact same problem as with B760 from ASRock.
Fortunately I was expecting problems so all board have been bought on platform with good return policy so I lost mostly time + some stress.
Also, my i5 13500 died during these test ( thanks intel ), IMC degraded so hard that it canât even keep two sticks at 4800Mhz, I replaced it with i9 12900k. Still no luck, only 2 sticks and no SR-IOV ( well CPU canât really do anything in terms of SR-IOV anyway ).
As I was doomscroling thinking if I should sell my kidneys to buy 2x 64GB DDR5, I noticed that for some reason Core Ultra 7 270k + Gigabyte Z890 Aero G combo was cheaper than any of the Asus Z790 + i9 that I had.
Hoping that the memory controllers improved I bought those, put them in my PC/Server and viola, it canât boot with 4 stick either
, fortunately moving 16GB dimms to primary slots and 32GB to secondary worked, it managed to boot at 4400Mhz but was not stable, it passed 2h memtest but failed when I booted from live ISO to do CPU stress test, clocking it down to 4000Mhz seems to have fixed it, at least I hope so, otherwise my ZFS will live in greener pastures.
But the most important part is that SR-IOV works like a charm, there is BIOS toggle that enables it, and unlike ASRock it actually works, B60 creates VFâs with no issue.
In case anybody is wondering, the custom i915 DKMS that enables SR-IOV for Alder Lake era iGPUâs is non issue, both the the XE-LPG and B60 work fine with it, even VMâs have no issue, my Jellyfin can even encode in AV1 now.
So my struggles have finally come to an end, thank to the Gigabyte board, if anybody has similar problems, then unfortunately there is no easy fix, current gen boards seem to have better support for SR-IOV but itâs down to luck mostly I think, some boards will claim to support it but will not work, so the best strategy is to buy board where you know you can easily return it and just keep swapping it until you get one that works. Or ask gigabyte support like the guys here: Arc Pro B60 SR-IOV or how my new homelab is driving me insane. - #3 by Kromas
