So after months and months of failure, I took another crack at trying VFIO GPU passthrough using Ubuntu 21.04, and various internet guides.
For some reason, I am getting the below issues when I try to run the VM attached with the GPU. This is a new box and a fresh install. I’ve probably overlooked something very obvious. Any ideas? Thanks.
Error starting domain: internal error: qemu unexpectedly closed the monitor: 2020-12-30T09:37:52.399631Z qemu-system-x86_64: -device vfio-pci,host=0000:08:00.0,id=hostdev0,bus=pci.0,addr=0xa: vfio 0000:08:00.0: failed to setup container for group 2: Failed to set iommu for container: Operation not permitted
Traceback (most recent call last):
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 65, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/asyncjob.py”, line 101, in tmpcb
callback(*args, **kwargs)
File “/usr/share/virt-manager/virtManager/object/libvirtobject.py”, line 57, in newfn
ret = fn(self, *args, **kwargs)
File “/usr/share/virt-manager/virtManager/object/domain.py”, line 1329, in startup
self._backend.create()
File “/usr/lib/python3/dist-packages/libvirt.py”, line 1234, in create
if ret == -1: raise libvirtError (‘virDomainCreate() failed’, dom=self)
libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2020-12-30T09:37:52.399631Z qemu-system-x86_64: -device vfio-pci,host=0000:08:00.0,id=hostdev0,bus=pci.0,addr=0xa: vfio 0000:08:00.0: failed to setup container for group 2: Failed to set iommu for container: Operation not permitted
