I'm running into issues getting Steamos xpad to install for a the Linux-CK kernel, on Arch Linux. Currently I need to switch into the normal kernel to use a gamepad. I did get CK kernel to work with the default xpad module, by enabling it as a module, while compiling the kernel, but the xbox 360 controller keeps flashing.
This is the error I get when installing the package:
Error! There are no instances of module: steamos-xpad
20160103 located in the DKMS tree.
error: command failed to execute correctly
tried deleting the xpad.ko.gz file from 4.4.6-1-ck kernel with no luck.
If I try to modprobe steamos-xpad I get:
steamos_xpad: Unknown symbol xpad_send_led_command (err 0)
modinfo steamos-xpad shows:
filename: /lib/modules/4.4.6-1-ck/kernel/drivers/input/joystick/steamos-xpad.ko
license: GPL
description: X-Box pad driver
author: Marko Friedemann [email protected]
alias: usb:v162Ep*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v162Ep*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v15E4p*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v15E4p*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v1532p*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v1532p*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v24C6p*d*dc*dsc*dp*icFFisc47ipD0in*
alias: usb:v24C6p*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v24C6p*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v1689p*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v1689p*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v0F0Dp*d*dc*dsc*dp*icFFisc47ipD0in*
alias: usb:v0F0Dp*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v0F0Dp*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v1BADp*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v1BADp*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v146Bp*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v146Bp*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v1430p*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v1430p*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v12ABp*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v12ABp*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v0E6Fp*d*dc*dsc*dp*icFFisc47ipD0in*
alias: usb:v0E6Fp*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v0E6Fp*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v0738p4540d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0738p*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v0738p*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v046Dp*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v046Dp*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v045Ep*d*dc*dsc*dp*icFFisc47ipD0in*
alias: usb:v045Ep*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v045Ep*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v044Fp*d*dc*dsc*dp*icFFisc5Dip81in*
alias: usb:v044Fp*d*dc*dsc*dp*icFFisc5Dip01in*
alias: usb:v*p*d*dc*dsc*dp*ic58isc42ip00in*
depends: usbcore
vermagic: 4.4.6-1-ck SMP preempt mod_unload modversions
parm: dpad_to_buttons:Map D-PAD to buttons rather than axes for unknown pads (bool)
parm: triggers_to_buttons:Map triggers to buttons rather than axes for unknown pads (bool)
parm: sticks_to_null:Do not map sticks at all for unknown pads (bool)
Anyone know how to get the package to install correctly?
