Installing/Formatting HDDs
I just built a computer running linux mint 15. When I try to access a hard drive or even the boot ssd an message pops up saying:
unable to mount location
Can't mount file
If someone could help soon that would be optimal.
Can you still access the logged in users home folder?
Yes, I can access everything on the os and I can also download things and find them. The only thing i can't do is go into the computer folder and access the individual hard drives. Also check my profile for PC specs.
The "computer" folder is the root. Linux doesn't work like Windows, it doesn't hide the assets on your computer. Start your file manager (Mint, that would be nautilus, so to start, type in terminal "sudo nautilus") with root privileges, and you'll see the content of the "Computer" folder, but you won't find what you're looking for, because you probably didn't sort your volumes logically, but rather the unsafe Windows way.
To see the content of the "computer" folder as normal user (but not change anything in it, because that should remain protected as a system safety measure), add your user to the group that has viewing permissions on that folder.
No problem, nothing serious, don't panic, you probably were just unsure about the permissions, and must have changed something somewhere during install in the normal parameters. Don't worry about it, just change the permissions, and you'll be fine. If you're looking for your storage as a device, these will be sorted in 4 different ways in the /dev/ folder ("devices"), and if you're looking for your storage volumes (the logical devices instead of the hardware devices), these will be in the /media/ folder for local storage and in the /run/media/ folder for external devices.
In order to mount internal devices at startup, add the option to fstab (just set it up to mount in gnome-disks, then you don't have to deal with fstab because it will do it for you, but it's easy if you want to deal with fstab).
I can go into the computer folder. And when I do I see the volumes (1 ssd 2 hdds). When I try to see what is in each individual drive I am prompted with this:
Unable to mount location
Cant mount file
Still having the problem?
You might enlighten us with some information on your system if you mind, the basic thing when you ask something linux related is to show tons of information.
Atm. i guess you run linux on the same computer where you had your windows-style formatted drives, so it is probbably that just opening such a drive is not a standard, so the system needs higher previliges to do such a thing and it needs to know how. (commands like-: # mount -t "type" /path/to path/to )
More information here http://linuxconfig.org/how-to-mount-partition-with-ntfs-file-system-and-read-write-access just guessing they are ntfs
The whole formatting and partitioning can be easly learned from the gentoo handbook here http://www.gentoo.org/doc/en/handbook/handbook-x86.xml?part=1&chap=4
Hope this helps you
