Installing Arch w/ bCache out of the gates
Hi all,
This is my first post here, but this seems like the best place to get good direction on building my first hardware backed Linux installation. I’ve played around with all distros under the sun in VMs and have finally come around to dumping Windows off my main machine and going full tux. One of the biggest things that has been holding me back is AMDs StoreMi solution, and from my research bCache is going to be my best bet. Arches wiki guides on installing it in an existing system, so I won’t be surprised if this is what this post comes back too.
My main concern is properly configuring my partition tables to minimize having to reconfigure anything later, since I’m already building from the ground up, I’d like to just lay the proper framework in the first place. I am using a UEFI enabled mobo (ASRock B450M Pro4) and have one 250GB SSD and one 1TB HDD, obviously the latter being the backing device in this config. (I’m going to use ext4, want to clarify because I’ve stumbled onto instances of similar questions spiraling off into ZFS/ECC compatibility arguments in my research)
This seems like a fairly simplified implementation of caching of this manner, and that may be why I’m missing the finesse of the wiki. If this is a RTFM question, please anchor link me to what I’m missing here.
Beyond that, how should my partition tables look to be most efficient going into this installation? Any caveats or gotchas I should be aware of as well? Can I roll into bCache during my base installation process with ease rather than building the OS and implementing once stable, or would it be easier to convert in post?
Thank you!
You would have to start here:
https://wiki.archlinux.org/index.php/Bcache#Installation_to_a_bcache_device
I would make /boot and swap separate partitions and then / on the bcache. That way bcache can decide the rest.
