My computer was running just fine for almost two months now. Today I tried to install another 1tb NVMe SSD.
I went into the BIOS to check the boot order. Ended up turning on XMP and virtualization as well. This caused boot loop with the BIOS and keyboard inputs freaking out.
BIOS was on F3. I tried clearing CMOS and reseating both SSD.
Ended up flashing new BIOS. So I am now on F6b.
It’s working normally I believe, I haven’t changed anything from default except Boot Order.
I still cannot boot into Windows.
I have tried:
a Linux boot USB and checked the primary SSD is still accessible.
a Windows boot USB to try to “Repair Startup” option.
booting with only the one NVMe SSD.
changing the M.2 slot from A to B on the board.
My long weekend is ruined, I have no idea what my next steps are. I am afraid of having to install Windows and all my software all over again. Is there anything you would suggest?
At this point I am unsure if I should install Windows on the Silicon Power drive and use the WD drive as the secondary.
Any help is appreciated. Please let me know what other information I can provide.
My specs:
Aorus X570 Ultra
AMD 3800X
GSkill 32GB RAM
RTX 2080
1 3TB HDD, 1 2TB HDD
Primary Windows
WD_Black SN750 1TB NVMe Internal Gaming SSD - Gen3 PCIe, M.2 2280, 3D NAND, Up to 3470 MB/s - WDS100T3X0C
New Secondary
Silicon Power 1TB NVMe PCIe Gen3x4 M.2 2280 TLC R/W up to 3,400/3,000MB/s SSD (SU001TBP34A80M28AB)
The “no bootable media … restart or select media” text error. I am uncertain when this could have happened as the thing that happened was BIOS problems.
Sorry, do you have a guide to follow? I couldn’t find anything that made sense to me. My USB has Ubuntu 18.04. The WiFi isn’t working, I don’t know if it is something I need to install.
What made you come to the conclusion that something is wrong with the partition? The partition shouldn’t have any problems unless you did something to it.
I keep trying to boot into my drive. One of the pictures shows the partitions are there and active but selecting the drive to boot is not working. I searched some stuff about how to find windows efi and came to some guides on boot recovery.
