Sup,
I'm here to ask some questions/get advice for a build I'm planning the coming month.
As my story goes;
I need a laptop for college, but I've chosen to get myself a mini-ITX system. At first I planned buying an Alienware x51 as it was very suitable for my needs and it could've be dragged around in a PS3-style bag. Then I found things like EVGA Hadron Air and Lian Li PC-TU200. My final choice now is the EVGA case just because it's smaller and cheaper than the Lian Li case. I want to use it as a "laptop" by taking it to college every CAD-lesson (which will probably be just one day in a week), and use a USB 3.0 monitor (Asus, AOC, etc.)
Why a mini-ITX system?
-it's upgradable
-the price/performance ratio is much better (the laptops which are suggested by the college are about €1800,-)
-it can be used for more purposes (the laptop has a high-end i7 processor, but and entry-tier mobile workstation card, so playing minesweeper would almost be possible)
-it's just, hardcore man!
This is the computer I'd like to build;
-i7 4770 or 3770 (does it mather that much?)
-GTX 760 or an AMD card with the same performance (AMD's are better at OpenGL, I need it for CAD)
-generic mechanic 1TB/2TB hard drive
-8GB/12GB/16GB RAM (I'll probably start of with 8GB, and increase it later on, speed doesn't mather at all as it has almost no real performance change)
So here are some of my question;
-what mini-ITX motherboard do I need for the Haswell CPU, and that could handle maximum 16GB RAM? It does not has to be one of those "uber-mensch-hardkoare-oavercloacking"-things for 300 million thousand euros. Just one within the range of ~€100.
-will the 5Gbit USB3.0 bandwidth have any influence FPS-wise, while using a CAD-program (Siemens NX 8.5 to be precise).
-will a latest "gaming"-card perform good enough for generic CAD-drawing? Potentionally I can just buy another entry-level €100 Quadro/FirePro-card if needed, and then swap it every time I need it for some super-cool engineering work.
For the owners of a Hadron Air case (or the guys from teksyndicate);
-is the top panel of the Hadron Air case sturdy enough to mount a handle on it? I'm planning to mount a guitar-amp handle into the holes.
or
-do you have any suggestion for a suitable carying bag for the case?
Please, accept this frog as a sign of respect and friendship.
Thank you.
Sincerely, Amir IV of Wales
