hey so I got my monitor and graphics card the monitor is dvi while the scars is dvi d so do I need a dvi to vga adapter?
If the monitor is DVI, why would you need a VGA adapter?
Because the monitor is too small for the cartithe graphics card is dvi d
Bump
are you using google translate? because i can't make heads or tails of what you're going at
if both the monitor and card are dvi then why would you need an adapter, and size shouldn't come into play at all, unless you have no idea what dvi looks like and are just calling everything dvi
No... My monitor is dvi cable while the card is dvi d
