So. I bought a ADXgaming keyboard from curry’s in the UK.
Was supposed to be mechanical with cherry like switches etc.
Turned out to be hot garbage after two months the W key only registered 95% of the keystrokes and is basically now just unusable.
However, the keyboard is RGB and has a nice standard rgb cycle so was wondering how I could get the keyboard to initialise without any fancy equipment or a PC to attach it to. The cheapest option so far was to maybe pick up a pi zero. But is there a cheaper option then this as I am basically turning a keyboard into a display item.
Any tips to get this done el_cheapo would be grand
I have no idea how ADXgaming keyboards are built, if they’re very similar to other generic mech keyboards it could be possible to take the switch apart to relube/change out the spring or replace the key switch completely. Many of the generic mech keyboards are just rebranded.
As far as lighting the keyboard without a computer, if you have a old USB charger that doesn’t have any “green power save”(some chargers auto shut-off after 3hrs) it should be plenty enough to keep the keyboard blinking in RGB pattern modes.
