I wanted to see if anyone out there knew if there was a way to individually sleeve a psu that isnt modular and if so does anyone have any good tips and or tricks to do so.
Modular or not all PSUs cables can be sleeved. You can get as close to the exit port (ie where the wires leave the PSU) with the sleeve or do sleeved extension cables. Otherwise you can void your warranty, open your PSU, and sleeve them so that the heatshrink side of the sleeve stays inside the PSU. Those are pretty much your options for non-modular.
Thank you for the help im a complete novice at this anything tips you might have Also im having trouble finding the cable sleeves that is not in like 200 feet increments. And the sleeving that i find its anywere from 1 inch to 1/2 and ive read that 1/8 inch sleeving is for individually sleeving
I am not sure where you are looking at for sleeving, but yes 1/8 is a typical single sleeve size also there are other places you can go without having to buy bulk 200ft sleeving. Go here: http://www.overclock.net/t/1262900/frequently-asked-sleeving-questions/0_100 for a good guide for sleeving beginners. Take your time and mull through it. Also you can look at this youtube channel ( https://www.youtube.com/user/lutro0/videos?view=0&flow=grid) for a more visual how to on sleeving. If you have any other questions feel free to PM me.
He is a small company from germany. By far the best sleeve available. When you become a customer you can join there private forum. Has so many tips for everything modding. http://en.mdpc-x.com/
